Normale Version: Sideways shifting
Hello all
One of My 1300 tracs, is very Hard to shift sideways, I lubed all the links, took the shifting system apart, greased every thing up,
Still Hard to shift sideways, back and for is No problem, bud sideways i need to use alot of power, the other 1300 is very smooth, allmost No power needed, bud i cant finde the difference.
Any one tried this?
Greeting
Hello,
Did you check evry part alone, if one Part goes hard?
I would dismount the shiftig linkage at the gearbox and check if it goes hard.
Normaly this goes very smooth.
If this is running very smooth, i think the Problem ist in the Shiftig box at the Gearbox.
Greeting Bernd
