Top speed MB Trac 65/70 1978 -
MercedesW124 - 07.05.2013
Hello. What is the top speed for a 1978 MB Trac 65/70?
RE: Top speed MB Trac 65/70 1978 -
Hartmut - 07.05.2013
25 km/h
How can I get it to go 40 KM/H?
holgi63 - 08.05.2013
Hallo "MercedesW124",
what's Your name?
40km/h only when You build in another gearbox.
The 65/70's drive has some fundamental "missing links" for 40km/h so it doesn't make sense to "upgrade" the drive...
Raising max. speed of the engine to 2.800/min makes nearly 30km/h...
FG
MercedesW124 - 08.05.2013
The seller is not quite sure if it's a 65/70 or 700. How can I find out? What is top speed for a 1978 MB Trac 700?
(08.05.2013, 14:11)holgi63 schrieb: Hallo "MercedesW124",
what's Your name?
Christian Ribe
MB-trac-AMG - 08.05.2013
Hello Christian,
Do you have the Chassisnr. on the MBtrac?
Unnskyld at jeg spør, men er du fra Norge
Greetings,
Haavard.
(08.05.2013, 19:14)MB-trac-AMG schrieb: Hello Christian,
Here is the chassisnumber 440162004254
(08.05.2013, 19:14)MB-trac-AMG schrieb: Unnskyld at jeg spør, men er du fra Norge
Greetings,
Haavard.
What? I don't understand..
Neida, du avslørte meg
Her er linken til annonsen forresten
http://www.finn.no/finn/b2b/agriculture/tractor/object?finnkode=41488118
Hartmut - 08.05.2013
(08.05.2013, 20:50)MercedesW124 schrieb: Here is the chassisnumber 440162004254
MBtrac 700
https://www.trac-technik.de/techn_daten/440-162.htm
The owner says that it only goes 25 KM/H
Can I get it to go 40 KM/H ?
Hallo Christian,
welcome to this forum!
440.162 is definitely a MBtrac 700, but: If this tractor was deliverded with 25km/h top speed as delivery condition, it has the same gearbox as the 65/70.
In this case, the main drive does not have built in the second transmission group. The box only can deliver 4 speeds, doubled to 8 by the reduction group.
Greetings
Thanks.
Last time it was for sale, this was in the ad (translated from Norwegian): This is an agricultural version therefore not high speed transmission.
MB-trac-AMG - 09.05.2013
[/quote]
Haha din luring.
Hilsen,
Haavard.
Robert Meyboom - 10.05.2013
Also habe keine Lust auf Englisch zu schreiben. Unser 65/70 hat die FG Nr.: 440162003560, haben ihn 1977 neu gekauft und ist laut Datenkarte 12/75 gebaut worden (war wohl einer von den letzten und hatte auch schon keine Schneckengänge im Getriebe) Das zum Thema 65/70 oder 700. Aber twas schneller kriegt man ihn wenn man eine neue Eingangsuntersetzung einbaut, was wir vor etwa 15 Jahren bei einer Reparatur mußten. Die originale war nicht mehr verfügbar und Walter Huhn hat ne andere eingebaut. Geschwindigkeit jetzt knapp 30 bei Nenndrehzahl.
Der alte Meister der MB Werkstatt Schultz Borken hat mir auf meine Frage was da die nicht benutzten Zahnräder im Getriebe zu suchen hätten erklärt, das mit ein paar zusätzlichen Bauteilen der Schlepper erheblich höhere Geschwindigkeiten erreichen könnte. (Ich denke mal das es dann ein 800 er Getriebe daraus würde) Auf meine Aussage "sofort machen" kam dann die Antwort das ihm seine Freiheit doch sehr lieb sei....
Also blieb es dabei und heute "schafft" der Trac mit der oben beschriebenen Maßnahme und ein paar n/min mehr dann seine gut und gerne 30 km/h.
Gruß Robert
MercedesW124 - 31.05.2013
The tractor is sold now. But not to me. I will wait to find one with 6 cylinder engine
Noxus13 - 31.05.2013
Also wir haben en 65/70 von Bj. 73 und haben vom 800er des Getriebe eingebaut. Läuft jetzt stolze 70 Km/h.
