Themen: 14
Hilsen / Regards / Grüße
Christian Ribe
Themen: 1.246
http://www.schreyer-online.com/trac_ersa...ckluft.htm
Umschaltventil:
Gänge 1-4 / 5-8
beim MB-trac 1300 - 1800
und beim UNIMOG
Themen: 124
Hi, I think at the next mercedes workshop but as far as I remember it is made by Bosch. If you remove the mud you will see the Bosch number. May be you can order it also from Bosch or Wabco.
Best regards Marcus
Themen: 14
It is only 2 part numbers on it.. As you see in the pictures
I need a new because this one is leaking air. From 8 to 0 bar air pressure takes only some hours
Christian Ribe
Themen: 14
There is no more to clean. The text is worn away
Christian Ribe
Themen: 159
Hello Christian.
take a look here ->
https://www.trac-technik.de/Forum/showth...?tid=18837&pid=118772#pid118772
