mb trac 900 turbo
hello I have mb trac 900 turbo with werner forst
And I have a problem with left winch
When I stop pulling the winch it is then pulling for 5 seconds before it ends
in that winch is brand new air pocket
the right winch stops pulling at the time I make the command.
please thell me wich derection I should go to repair this
We had the same problem.
since cleaning the pneumatik valves and using an small pre-airfilter it is working properly. Small dirt paticles had caused the valve to slow down an jam.
best regards
Wulf
