Einspritzpumpe om 364
Hello , my deutch is not so good , so i write in english.
I want to change the motor in Mb trac 800 . I have now 314 and i bought om 364 to put in. I want to start the engine but i found a problem at injection pump . I see that is has to be linked to intake? From the end of the pump i have to link with a tube to intake?
Thanks
Hello Calin,
can you give aus some fotos?
I think it is easier for us to see the problem and to answer.
Best regards
Franz-Josef
Can I use the injection pump from om 314 to om 364? I saw that are quite identical.
