Themen: 2
I want to change my engine from mb trac 800 . i have an om 364 from a 811 D truck..
I want to start the motor but i thing the starter is not enough to spin the motor. should i put a 24 v starter?
Themen: 17
30.11.2019, 20:52
(Dieser Beitrag wurde zuletzt bearbeitet: 30.11.2019, 20:52 von
Stefan700Turbo.)
I think you put in the Starter from the 811 truck into your MB Trac. This one needs 24v but your Trac only has 12v. You only have to put the Starter from the OM314 into the 364 and it should work.
Themen: 2
Then i have to mount 2 battery ? Where are they mounted in mbtrac 900?
Themen: 13
01.12.2019, 09:07
(Dieser Beitrag wurde zuletzt bearbeitet: 01.12.2019, 09:07 von
trac 65.)
Hello you have put the 24v Starter from the Truck into your MB trac(12v). You must put the Starter from the old Engine(OM314) into the new(OM 364). Than the Starter have enough Power to turn the Engine. That is easyer as changing all Components of the MB trac electric to 24V.
MB-trac 65/70 - denn auch mit 25 Km/h kommt mann ans Ziel
- 440 161 001068
- 440 161 000446
- Hanomag Perfekt 401 der Hannoveraner in der Truppe
Gruß Luca
