MBtrac 1000 rear linkage slow to drop
XTRAC15
Hello all, I'm new here, I live in York, UK, I have a 1986 Trac1000 with a number of issues due to its age and high hours,
My current problem is that the rear linkage is slow to drop, I have changed the filter and the oil in the hydraulics, I did found part of the seal in the bottom of the filter housing was missing and have since found bits of it in the valve block, any other ideas what may be restricting the return flow.
It also sometimes is slow to lower a raised tipping trailer, but when the pipe is swapped to the dump connection it drops fine.
Many thanks Simon
