Hello
My apologys for english writing....
I discovered that my cluch pedal went straight to the floor without disengaging the cluch and investigation revealed a bursted rubber piston seal in the slave cylinder.
The reason was old rotten rubber and I suspect someone at some point filled the reservoir with washer fluid or similar....the stuff that came out was not brake fluid....it is not possible to read anything on the old seal.
I found out that the cylinder and piston was in good condition and and tried to buy a repair kit...to no success so far.
The repair kit should look something similar to the attached [url=
]picture[/url]
The challenge is to find a seal with correct diameter![Sad Sad](https://www.trac-technik.de/Forum/images/smilies/sad.gif)
The piston has the following diameters and meassures:
Large diameter is Ø=28,36mm
Piston shank diameter is ø=19,1mm
Reccess height in piston is 6,3 mm
The bore diameter on the slave cylinder is 28,59mm
I hope maybe someone here have some good suggestions where to find such a repairkit with piston seal and a new rubber boot that can fit my MBtrac 700K 1984 model. Here seen with a large wich on the front loader...![Big Grin Big Grin](https://www.trac-technik.de/Forum/images/smilies/biggrin.gif)
Thanks for any contribution
Have a nice day
Have a nice day
![Cool Cool](https://www.trac-technik.de/Forum/images/smilies/cool.gif)
