05.12.2017, 10:39
Hello from Australia,
My 1300Turbo is nearly ready for work, with only some minor throttle issues to sort out and the brakes to re-bleed. It has been repainted, repaired front pinion, new comressor, starter motor and water pump, new electrics and a full service. Now that I have fixed the air leaks and new compressor I can try and bleed brakes as they are only at about 50%. I have renewed the pads and adjusters, is there any tricks to getting the brakes working properly, now that they are adjusted correctly?
